Question about Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability
I have a casio keyboard and if i plug headphones into the audio hole they dont work it just plays out loud. help.
Posted by amy_sciberra on
Fred Yearian
  • Casio Master
  • 5,603 Answers
It is important that your headphones are STEREO tyoe as a monaural 1/4 inch plug will short out one side of the output audio.
Make sure the plug is fully seated as it has a switch in the unit that disconnects the speakers typically when headphones are plugged in.
If your speakers do not get cut off when you plug in the headphones, it is POSSIBLLE that the switches on the jack have been broken. This would require servicing.
Posted on Dec 28, 2009
The headphone plug broke off in the jack and I can not get the end out. is that what could be causing no audio at all? this is a Casio Privia music keyboard px400r
Yes that is sure likely to be the reason as when the headphones are plugged in the audio is disabled to the device speaker
Dec 27, 2016 | Casio Music
Piano does not work no sound can be heard power supply is on display is proper too. if head phones are used i can hear the sound. but no sound can be heard without headphones tried to play a song through...
I could not find the schematic for this, but other Casio units use a common voltage regulator amplifier chip to drive the speaker... I would firsst check that leads to the speaker have not become disconnected.
Jul 19, 2011 | Casio SA76 44-Key Mini Personal Keyboard...
The external speakers attached to my m audio prokeys 88sx are no longer working. I have replaced the fuses in both but the fuses blow on power up. I then used the keyboard with a set of headphones. One of...
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
Jan 16, 2011 | M-Audio Pro Keys 88 Premium Piano
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
The audio is not coming out what to do
First, check your volume. Try turning it up the whole way. If that doesn't work, then try moving the slider switch to normal, and playing.
Also, try using the keyboard in Song Bank mode. If you have a Sustain Pedal, make sure it's in the accessory port and not the Headphone port. If none of this works, then you may have blown a speaker. Parts are cheap from Casio ($13.00) and are relatively easy to put in yourself.
Dec 30, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Headphones arent working with keyboard
yes its in the keyboard jack.
Aug 14, 2009 | Music
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Ctk 496 Electronic Keyboard with 61 Keys, drivers needed
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
Dec 30, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability Logo
3,552 people viewed this question
Top Casio Music Experts
Ekse
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
