SOURCE: how do I clean my tv remote for toshiba ct-9809
Very carefully remove the batteries and there are a set of screws all around the back of the remote you can take it apart the buttons are all on one sheet of plastic so you can take that off and use a light amount of water on a q-tip to clean all the connections on the circuit board
SOURCE: toshiba ct-847 remote controls codes
go please www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
0219,0216,0211,0215. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
