Hi, wondering if anyone can solve this. The indoor unit, when switched on, is flashing 10 orange timer lights and the main red power light flashes continuous. When I turn the indoor unit on the fan seems to work but there is no cooling. After about 5 minutes the indoor unit shuts down and the flashing lights are displayed. The outdoor unit doesn't seem to be kicking-in at all.
What is the model number of your equipment. I'm only seeing a 9 flash and that points to a faulty reversing valve.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Test the fuses for the outside unit.
SOURCE: System will not start up.
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at [email protected]
Thank you very much.
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
SOURCE: fujitsu outdoor unit not working
Its possible there has been a power spike and it has dammaged the power pcb. Remove the cover and inpect the PCB's for blackening. If any blakening replace the damaged PCB.
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
