Kingston 2GB Secure Digital Memory Card Logo
A
Anonymous Posted on Jan 17, 2014
Micro sd driver - Kingston 2GB Secure Digital Memory Card
Micro sd adapter driver
"device driver software was not successfully installed"
Find the correct driver for your computer and operating system.
How do i transfer my photos from my kin one to the computer? when i plug in the usb cord it says i need a driver software, which i don't think it came with
If your photos are stored on a micro or mini SD memory card then -
An alternate method is to remove the mini or micro SD memorycard from the cell phone and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the micro or micro SD memory card and copythe photo to your computer.
52helpful
2answers
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
1helpful
2answers
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
1helpful
2answers
How shall i put in a kingston 1gb micro sd in a All in 1 card reader
You should have 2 components with your micro SD card. The card, a small adaptor and a large adaptor. All you need to do is see what size adaptor your read needs. You place the card in the tiny slot in the adaptor and slide it in the reader. The computer will find the micro SD and install the driver to read it. Then it will give you an option to open the files. That is how 99% of them work.
2helpful
Acer aspire one won't see my olympus SD MASD-1 micro SD attachmen
You may need the card reader drivers installed. What is the exact model (110, 150, D150?) and operating system of your laptop?
Drivers can be found at the following link given the model of laptop, I can help you find it further if you provide the requested info above.
http://support.acer-euro.com/drivers/downloads.html
1helpful
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
2answers
6233 Micro SD Adaptor cannot work!
Make sure you have the latest SD drivers installed for your motherboard, first. Then put the SD card into your computer and Format it. Then , try transferring files.
Hope this helps
Chris (ziraffa)
Vaio and micro sd
Appreciate the direct "Ask Me".
Since you have verified that the card works (in your phone) and that the adapter works (in another computer), then the issue could very well be with the Sony VAIO VGN-C140G/B. More specifically, the USB ports/drivers. Presumably that the Sandisk 2Gb Micro SD & the adapter were working before and that you are using Windows Vista, pls check your updates that has anything to do with USB. Alternately, you may want to rollback/downgrade the USB drivers and/or seek USB driver update from the Sony site rather from Microsoft.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
20helpful
3answers
Driver software for MicroSD needed?
http://www.spectec.com.tw/fix.htm
try the above link, it might be usefull
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
