I have a Linksys wireless router plugged into my SpeedStream 5100 Modem. How do I lock out neighbors from using my wireless internet signal?
1. First you must set password to access the web interface, so that only you can change the setting.
For a linksys the default web-interface is at 192.168.1.1 The first term you access it enter username:admin, password admin. If that does not work read the manual to find that out.
2. Explore the TAB and each sub-menu to familiarize yourself with the interface. For change to Take effect you must SAVE. Button is at the bottom.
3. In the TAB SETUP>Basic Setup Activate the Automatic DHCP reservation of IP addresses. Enable it on the same page
4.Under the ADMINISTRATION TAB >Management enter a new router password.
5. Under the Wireless TAB> Security Menu, select the Security Mode as WPA2Personal, and Encyiption AES. Enter a passphrase ( like a password but can be a phrase -part of a sentence. For key renewal enter a number like 3600 seconds.
Save all.
Now if you connect a device through the wireless you will be prompted to enter the pass-phrase. You will be asked for it after every power down of router or reboot of router. If you reset the configuration by pressing the reset button on the router you must redo everything again.
Remember: You will erase everything every time you reset the router. So if you make mistakes, just reset it with a straightened paper clip.
Remember, any body who has physical access to the router can reset. If tech savvy, he/she can give him/her/self access.
SOURCE: Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
SOURCE: speedstream 5100
red light on DSL implies no ADSL communication to ISP. Check your phone line connection and make sure there are filters on all the other phone equipment in the home
SOURCE: Speed Stream 5100 connects to a linksys router wireless G
change the modem place and check the connection
thank u
SOURCE: can"t get on the internet using 5100 speedstream modem my
in your browser type 192.16.0.1 and it will take you to the modem admin page.
Press the check connection button and it will tell you how your connections are doing. If it shows DSL/Internet down, then most likely your ISP is down 95% likely), or your modem is bad (happens pretty often with these things)
If it doesn't take you to the page, try using 10.0.0.1
some of the newer 5100s have that as their address. Same options and advice.
