SOURCE: 1987 ford Bronco II fuel gage doesn't work-reads empty all time
I need to know if the other gauges are accurate. There is a voltage regulator mounted on the back side of the dash that can go bad and often does, that will make the other gauges inaccurate also.
SOURCE: 1966 Ford Mustang Gas Guage not working
I had a similar problem. In my 1966 Mustang gas tank, the fuel pick-up was on a "float." My float developed a hole, filled with gasoline, and sank to the bottom of the tank, therefore, the gauge always read empty, but the car ran well. All the other gauges of course worked correctly. The repair was a relatively simple soldering job (after removing the float from the tank), but if that is indeed the problem, ensure all the gasoline is drained from the float before beginning the soldering job.
SOURCE: 2001 chevy silverado 4.8 gas gauge not working properly
Fairly common problem with GM vehicles. The sending unit in your tank has a small circuit board that an arm is attached to which moves up and down according to your fuel level. This circuit board and arm are not making good contact. Unfortunately the only good solution is to replace this part.
Testimonial: "thought probably that was it but better off replacing whole unit .i was for for gauge proplem thanks. "
SOURCE: Gas gauge is not reading correctly. Shows a full
the problem is caused by a defective gas gauge sending unit, this part is located inside the gas tank, you must remove the gas tank to replace it.
