The carby has been replaced with a reconditioned carby Stromberg bxv-2 I set the float as per manual the car ies and starts every time once running wormed up leaving car over night then start again I have to pour a small amount of fuel down the carby what other things can I do
Adjust the choke. If the choke is ok the take the top off the carb first thing in the am and see if the float bowl is dry. If it is dry you need to find out where it is leaking fuel.
Testimonial: "the float bowl has 16mm of fuel as per the manual when you take carby apart choke has been adjusted as per manual no visual signs of air entering the system either"
Fix the choke to work properly for starters next if you still have the original cast iron manifold then get the butterfly in the exhaust to work as well. It heats up the inlet manifold which helps to vaporise the fuel
SOURCE: If the fuel pump in an Holden Barina 1998 model is
Yes you can just change the fuel pump, there are genuine and aftermarket options available, You need to remove the original pump from the cradle and this will allow you to confirm the size of the replacement pump.
SOURCE: Can you show me a diagram of a fuel pump and steps
Holden ,well its a vauxhall or opel to me so its the same and as such the fuel pump is not repairable ,their is a gauze filter on the bottom and check the wires from the connection block into the pump and thats it its a complete unit if it goes wrong complete with the float assembly .you owe me a tinny for this if i ever get enough dosh to visit my son in adelade and two grandaughters .
SOURCE: Wk Caprice heater blowing cold air? Fitted new heater tap and still blows cold a
sounds like you may need to replace the thermostat and also check fluid level....hope this helps ....good luck
SOURCE: my car wont start
sound like coil,or maybe ignition modual. check plugs and see if they are firing....hope this help...
