DRAINING THE SPA:
1. Unplug power pack from electrical receptacle before draining spa.
2. Put the rubber plug into the outlet in the inner wall of the spa.
3. Open the outlet in the outer wall of the spa. Screw one end of inflation hose into it.
4. Remove the rubber plug from the outlet in the inner wall of the spa.This will allow water to flow out of the spa. 5.When water is completely drained, press BUBBLE and run for 2-3 minutes to drain the water in the air pipeline. 6.When drainage is finished, remove the inflation hose and replace cap on outside of spa. Store rubber plug for future use.
SPA STORAGE
Make sure all water is drained from the spa and control box.This is essential to extend the life of the spa.We recommend the use of a wet/dry vacuum to blow out or suck up water from the spa pipes and pump lines. Remove the filter cartridge. It is recommended you store the spa in its original package in a warm, dry place.
Note: Plastic becomes brittle and susceptible to breakage when exposed to subzero temperatures. Freezing can severely damage the spa. Improper winterization of your spa may void your warranty.
http://img1.wfrcdn.com/docresources/17478/11/119999.pdf
