Radio Communications Logo
A
Anonymous Posted on Dec 21, 2013
Where is the mode key on scanner
Where is the mode key on my scanner
How to solve Ricoh sp 212SNw scanner carriage error
  • 1Press the "Clear Modes" button. This button will be on the main panel of the Ricoh copier.
  • 2Press the "1,0,7" keys in succession. You do not have to hold the buttons down at the same time but need to press and release them in this exact order.
  • 3Press and hold the "Stop" key. You will need to hold this button down until the Ricoh copier enters into service mode. The touch screen display will read "service mode" and three soft keys will appear.
  • 4Press the "exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
  • 5Turn off the main power. The main power button will be located on the side or front of the copier, depending on which Ricoh model you are working on.
  • 6Turn the power back on. Once the copier is powered back up, the service code will be cleared.
  • tip
    Barcode scanner reapir tips
    Loading Scanner: With the scanner powered off press and hold the SHIFT key & BK SP key on the scanner. While holding those two keys down press power, let power key go and then let SHIFT and BK SP go. The scanner will now go thru a reboot process. When done the scanner should read:
    “ COMMAND MODE “
    Select function
    Self Test
    At this point press the up arrow key twice and the scanner will now read:
    “ COMMAND MODE “
    Select function
    Program loader
    Place the scanner in the cradle and press enter. The scanner may or may not give a message saying “ WARNING: EEPROM WILL BE ERASED CONTINUE? “ At this point push enter. Let it erase the EEPROM. When done the scanner will ask you for “BAUD” press the up arrow twice and the scanner should read 38400. Press enter and, the scanner will ask you for “data bits”, press the up arrow key for 8 bits. The scanner will now prompt you for “flow control”, press enter. The scanner will now be on a screen that says:
    “COMM Parameters”
    Start? <ENT>
    Just leave the scanner at that screen for now.
    There is a file you need to test its called Diags.hex that needs to be transferred to the unit. once that is downloaded you can test the laser memory and even the keyboard.
    on Dec 01, 2009 • Computers & Internet
    How do I change the band from FM to AM on a Yupiteru MVT-7100 scanner please?
    Changing receive mode
    1. Press FUNC + MODE
    2. Use rotary control or arrow keys to select receive mode 3. Press ENT to accept change or C/AC to cancel
    Will not feed 11x17
    You probably need to set the user settings to "long doc" mode.
    1) When the machine is in the standby state,
    press the NEW FILE key and Count Only key
    simultaneously. During the user mode, the
    LEDs of the NEW FILE key and Count Only
    key illuminate and the address (U01-U10)
    and data (the last digit) appear on the
    counter display.
    2) When changing the address, use the NEW
    FILE key. Each time NEW FILE is pressed,
    the address changes, cycling from U01 to
    U10.
    3) When changing the data, use the Count Only
    key. Each time Count Only is pressed, the
    data changes.
    4) Pressing the Stop key exits the user mode.
    Long document mode =U10; 0=normal and 1=long document mode.
    Happy Scanning!
    Scan-R-Store
    Scan Store provides service and maintenance contracts on all Canon Fujitsu...
    2helpful
    How to turn off hyper scan
    The PRO-94 SCAN speed is fixed at 50 channels per second and cannot be changed/switched. Hyper SEARCH can be switched ON or OFF by pressing the PRIORITY (H/S) key while the scanner is operating in SEARCH mode. The scanner operates at 100 steps per second in normal search mode. In HYPER search mode it displays HYPER and operates at 300 steps per second.
    Need the manual for your scanner? You can download and print it, at no cost, here:
    http://support.radioshack.com/support_electronics/doc61/61172.pdf
    Bill B.
    Listening in since the 60's
    I have a pro 97 hand held cant get it out of clone mode
    Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
    To INITIALIZE the PRO-97:
    1. Turn the scanner OFF.
    2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
    3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
    4. Press the 1 (one) key.
    5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
    Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
    Once the process is complete you can begin to reprogram the scanner.
    Bill B
    I am getting a flashin L and can't make copies?
    L1 = Scanner (reading) feed trouble Scanner (reading)
    L3 = Scanner (reading) return trouble Scanner (reading)
    Reset method :
    * Entering the simulation mode
    1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
    (The machine is ready for entry of the main code of simulation.)
    2) Main code input by 10-key ? Start key ON
    3) Sub code input by 10-key ? Start key ON
    The machine enters the selected simulation mode.
    Press the start key to start the operation of the selected simulation.
    Main Code =(14 Used to cancel the self diag other than U2 trouble.)
    Sub code = 0
    * Canceling the simulation and returning to the normal mode
    1) Press the clear key.
    Copy SIM 14
    2helpful
    How to tell what the buttons do?
    The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
    SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
    FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
    All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
    http://www.uniden.com/pdf/BC92XLTom.pdf
    For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
    www.RadioReference.com
    Bill B
    Threre is a key in theupper left that i can't get rid of and can't get to another scanning mode Scanner 82 from radio shack
    Press and hold the bottom left key (looks like a light bulb with a key above it) until the key on the screen disappears. That will release the safety lock and restore the scanner's normal functions. Need the manual for your scanner? You can download/print it here:
    http://support.radioshack.com/support_electronics/doc69/69887.pdf
    Stuck on scan mode
    Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
    ***using the keylock ***
    Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
    To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
    The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
    Top Kenwood Radio Communications Experts
    eradiostore
    eradiostore
    Ngoro
    Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
