2003 2004 2005 2006 2007 03 04 05 06 07 Fx35 Fx 35 Unique Red Logo
G
Georges Assaf Posted on Dec 08, 2013
Fx 35 2004 code 0340 cmp sen circuit b1
Code p0340cmpsen circuit b1
advance tire and auto mauldin sc. text only
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Dec 11, 2013
Contributor
Level 1:
New Friend:
Answers
41
Questions
0
Helped
10391
Points
84
There is an updated cam and crank sensor for 3.5 engines
How to fix code P0340
code p 0340 refers to cam shaft position (CMP) sensor A, bank 1--circuit malfunction===causes --wiring --CMP sensor---ECM
1helpful
How to fix OBDII CODE: PO 340
code to 0340 refers to cam shaft (CMP) sensor A , bank 1 ---circuit malfunction===causes -- wiring--- CMP sensor --- ECM
check all wiring and connections to the sensor , replace the sensor
I have a PT 2010 & the diagnostic codes are PO340, PO344 and PO325. mechanic is suggesting replacing the cam shaft post sensor & didn't even mention the knock sensor. Am I dealing with 1 or 2 issues
you are dealing with 2 issues
code p 0325 refers to knock sensor (KS) 1 bank 1--circuit malfunction ====causes ---wiring ---poor connection ---KS
code p 0340 refers to camshaft position sensor(CMP) sensor A bank 1--circuit malfunction===causes wiring--- CMP sensor ---ECM
code p 0344 refers to CMP sensor A bank 1 --circuit intermittent===causes --wiring --poor connection---CMP sensor --ECM
check wiring and connections before replacing the CMP as the wiring may be the cause of all the codes
My car is showing p0340 camshaft sensorit was replaced and car still wont start, due to a faulty fuel gauge ran car out of gas also but fuel is on the rail, NO fire, thinking I lost timing,need help
code p 0340 refers to camshaft position(CMP) sensor A bank 1--circuit malfunction===causes wiring---CMP sensor ---ECM
because it denotes bank i ( bank closest to the fire wall) did you change the correct sensor
check for wiring and harness conditions ait it may run close to the manifold and be worn through or broken at places
My 1996 nissan truck cuts out in warm weather and has a troubleshooting code P0340
code p 0340 refers to camshaft position sensor ((CMP) sensor A bank 1---circuit malfunction====causes --wiring---CMP sensor---ECM
check the wiring and harness connections
change the CMP sensor
I have a 2006 dodge stratus sxt with a 2.4 l 16 valve engine. i was driving fine. when it suddenly developed a bad hesitation at 60 mph. as long as i stay under 2200 rpms it runs fine but once over 2200 it...
code p 0457 refers to the EVAP system--leak detected
code p 0340 refers to cam shaft position sensor A bank 1--circuit malfunction == causes --wiring ---CMP sensor ---ECM
at this point I would be checking the Cam shaft position sensor and wiring as it could be failing at rpm's and causing the problem
1996 Dodge Neon Code P0340 152000 miles the car died on the interstate at 60 mph & while coasting to the side it started back up & this is the code I had at the parts store. When it started up the...
code p 0340 refers to cam shaft (CMP)sensor A bank 1---circuit malfunction===causes --wiring---CMP sensor ---ECM
indications are faulty harness connections , faulty wiring (stopping the starting indications ) and lastly replace the sensor
Hi there, I have an 03/53 plate WJ Jeep Grand Cherokee 2.7CRD auto. It has the engine light on and was jumping in and out of limp mode. Now it seems to be constantly in limp mode and no diagnostic...
code p 0340 refers to cam shaft position sensor(CMP) sensor A bank 1--circuit malfunction====causes --wiring-- CMP sensor-- ECM
code p 0700 refers to transmission control system/ MIL--malfunction===causes --wiring---TCM
parts are available on line from e-bay , wreckers , junk yards manufacturer spares departments and would be delivered within 30 days so why are you waiting 7 months to get parts
1helpful
Trouble codes
Trouble Code: P0139
O2 (B1 S2) Slow Response
Trouble Code Conditions:Engine started; vehicle driven at 20-55 mph with the throttle open for 2 minutes; ECT at more than 158ºF (70C); catalytic converter temperature is more than 1112F (600C); and EVAP purge is active. O2 Sensor signal voltage switches less than 16 times from lean to rich within 20 seconds during monitoring, or will compare the state of change between the front and rear O2 Sensors and if the differences are greater than a calibrated amount, the DTC will set. 3 good trips are required to turn off the MIL.
Possible Causes:
  • Exhaust leak
  • O2 element is contaminated, deteriorated or it has failed
  • O2 signal circuit or return circuit has failed
Trouble Code: P0344
Camshaft Position Sensor Circuit Intermittent
Trouble Code Conditions:Engine cranking or running; system voltage over 10.5v. The PCM detected an intermittent loss of the CMP Sensor signal during the period of 2.5 complete engine revolutions. The failure counter must reach 20 before this code matures and a code is set.
Possible Causes:
  • Wiring harness fault
  • 5v supply circuit open or shorted to ground
  • Tone wheel/pulse ring is damaged or corroded
  • CMP Sensor has failed
  • CMP Sensor signal circuit is open, shorted to ground or battery voltage or 5v supply
  • CMP Sensor ground circuit is open
  • PCM has failed
  • Trouble Code: P0340
    No Camshaft Position Sensor Circuit Failure
    Trouble Code Conditions:Engine cranking or running, system voltage over 10v. The PCM detected CKP pulses without detecting any CMP Sensor pulses for 5 seconds or 2.5 engine revolutions.
    Possible Causes:
  • CMP Sensor connector is damaged, open or it is shorted
  • CMP Sensor signal circuit is open or shorted to ground or to battery voltage or 5v supply circuit
  • CMP Sensor 5v supply circuit is open or shorted to ground or to battery voltage
  • CMP Sensor is damaged or has failed
  • CKP Sensor is damaged or has failed
  • PCM has failed
Good luck....
Top Infiniti Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Joel Kobina Acquah
Level 1 Expert
Are you an Infiniti Vehicle Part and Accessory Expert? Answer questions, earn points and help others
