Try to change the memory modules...if there is two inset 1 at a time and boot ur system to check if u still face the problem....if not try borrow a memory module..and check....it looks like its the memory in your case but if you u still have problem having verified that its not the memory...
First of all, you need to understand what "System32 corrupt or missing" actually means.
System32 is a vital part of your PC. You can look at it as the
heart and brain of the Windows operating system without which, your
computer would not be working at all. System32 is usually located in
the C: drive under C:WindowsSystem32 or C:Winntsystem32 and is usually
hidden in order to prevent any accidental alterations by the user.
Reboot your PC and press F8 during the booting sequence until you
get into the boot menu. Select "Boot Using Last Known Good
Configuration". Your PC will now try to startup using a configuration
that has worked in the past. If you are still facing the System32
corrupt or missing error, you could try the following but you have to
be careful. In case you are not comfortable messing with your system
files, skip this part and continue reading the "Quick and Easy Fix"
paragraph.
Use the Console to Fix the "System32 Corrupt or Missing" Error
Insert your Windows XP Recovery disk and reboot your PC. If you
don't have a recovery disk skip this paragraph. Select the Recovery
Console and type the following into the console.
This will recover your windows system but you need to be
extremely careful that you are typing correct commands or everything
gets even worse.
md tmp
copy C:windowssystem32configsystem C:windowstmpsystem.bak
delete C:windowssystem32configsystem
copy C:windowsrepairsystem C:windowssystem32configsystem
Quick and Easy Fix
In case you don't feel comfortable messing with your windows
system; I suggest using a Windows System Repair tool which will scan
your System and list all system errors before attempting to fix it.
Besides solving the System32 corrupt or missing error, a system repair
tool will ultimately speed up your System as it cleans and reorganizes
your registry and deletes unnecessary files.
A commonly used tool is Errorsmart which is available for free at http://www.SpeedUpMyPc.Info Before re-installing windows or messing with your system, give Errorsmart a try and check if it is able to fix system32 corrupt or missing error
keep me posted
Hello Equalizer331,
Usually the most common beep codes have to do with Memory errors or bad Ram. click here for a Beep Code Guide
PAGE_FAULT_IN_NONPAGED_AREA Error or associated with memory error and causes memory dumps and print out the Blue screen you notices. The System 32 error you see is a general error that can mean a multitude of things that cause the error. Possible solutions is to clean the dust from inside the case and reseat the memory chips, also maybe removing them and trying them in diffrent memory banks might help. The last thing you might trying is replacing the memory.
In a Second scenario you could have some corrupt systems files that could be causing the system to crash. This can some times lead to beep codes or clicking sounds coming from the computer.
Please rank this soultion if it has help you, thank you and good luck.
I would test the memory first then try to reinstall the operating system i think your memory is on its way out
