When i connect my hard drive to my laptop the baloon comes up saying that usb device is unrecognized.
SYMPTOMS:
loadTOCNode(1, 'symptoms'When
you plug a USB device into a Windows XP-based computer immediately
after the computer comes out of standby (S3) or hibernate (S4), the
computer may not recognize the USB device. When this issue occurs, the
USB device may be listed in Device Manager as an unknown device, and
you may receive the following warning message:
To work around this issue, use one of the following methods:
Method 1
loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2
loadTOCNode(2, 'workaround');After the computer comes out of S3 or S4, unplug the
USB device, and then plug the device back into the computer or hub.
Method 2
Method 4
loadTOCNode(2, 'workaround'); Disable power management of the USB
hub.
Note If you perform the following procedure, you may also reduce the
battery life on a portable computer.
To disable power management on
the USB hub, follow these steps:
1.
Click Start, click
Run, type devmgmt.msc, and then click OK.
2.
Expand the Universal Serial Bus
controllers node, and then follow these steps for each USB Root Hub
that is listed:
a.
Right-click the USB Root Hub, and then click
Properties.
b.
Click the Power Management tab.
c.
Click to clear the Allow the computer to turn
off this device to save power check box, and then click
OK.-------------------------------------------
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
I am on a Mac. So, it looks like it isn't 2.0, but can handle 2.0. I had a feeling because when I added a new hub, everything seems faster than those plugged into the Pertech.
Thanks for answering.
MeeooW
Susan
Thank you. I have decided to replace it with a new 2.0 hub.
Susan
Found this at a Mac forumn:
Per the Pertech company, when their website was up:
Compatible with USB2.0 Our hub works with peripherals and hubs that are
USB2.0 compliant. USB2.0 Peripherals must be designed to throttle down to
USB 1.1 speeds
