My friend give me this tv but without control remote, can i buyed in argentina??
If you wish to buy its original remote control, you have to
contact the authorized service center.
If you wish to buy a universal remote control, you should know about,
which brand remote control have setup code to your TV/device brand. You should first
make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even
2-digit codes. You can get this detail by the code list attached to every
universal remote control. The brand
name of the remote control you select isn't a matter; but, its code list should
have setup codes to your TV/device brand, otherwise you can't set it up with
your device. Check out, which brand
remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to
some popular brand remote controls are given.
Check it, and determine which brand remote control should be bought, and
buy that brand remote control, according to availability.
If you wish to get more details, check the sites linked
here. Set-up code list, and Set-up
procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic
/ Timeslide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy.You can also do a search, by type in the brand
name of your TV / Device, in the search box at the top right of the display
window.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: Samsung 50" Plasma TV no response to remote ctrl & buttons
No need to exchange the Logic Board.
Need to exchange the IR modue.
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
