20 Most Recent Broksonic TV Questions & Answers
2answers
Need a manual for broksonic ccvg-2250.
This site may have what you are looking for http://www.manualsonline.com/
2/28/2019 12:52:09 PM • Broksonic TV • Answered on Feb 28, 2019
How can I switch from digital to analog?
If this is a CRT then you do not have a choice to get digital over analog. It is an analog TV. You can get what is called a scan converter to convert a digital signal to an analog but you will not be viewing a digital signal. To view a true digital signal you need a digital tv that has a resolution of 720P or higher. Most TVS are 1080P standardize which is the most common.
2/2/2016 3:51:17 AM • Broksonic TV • Answered on Feb 02, 2016
2answers
How do i get the menuon with out a remote
There should be a menu button along with the volume and channel buttons. Press menu and cycle through the settings using either the vol or chan buttons. good luck
1/24/2016 7:40:47 PM • Broksonic TV • Answered on Jan 24, 2016
I need the code for universal remote.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
12/1/2015 12:34:30 PM • Broksonic TV • Answered on Dec 01, 2015
HOW DO YOU RESET
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
10/18/2015 1:49:14 AM • Broksonic TV • Answered on Oct 18, 2015
The TV does not go on and the remote isn't working
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
10/7/2015 1:54:31 PM • Broksonic TV • Answered on Oct 07, 2015
(CTGV 5463 MODEL)-MANUEL FOR BROKSONIC COLOR 19 INCH COLOR TV
www.retrevo.com/ Try this site to download it. Gopakumar Gopalan Google
2/11/2015 5:09:29 PM • Broksonic TV • Answered on Feb 11, 2015
0answers
The TV cuts off randomly and often.
probably the power circuit, especially the caps are blown.not user serviceable. send it for professional repairs
10/16/2013 9:23:28 AM • Broksonic TV • Answered on Oct 16, 2013
How to know what power cord to buy
Just specify the model number to this set to its authorized dealer. They can provide it to you.
6/23/2013 1:05:04 PM • Broksonic TV • Answered on Jun 23, 2013
What is the jack on the back of my broksonic tv ccvg-3276?
Picture?
12/29/2012 10:45:21 PM • Broksonic TV • Answered on Dec 29, 2012
Black box on screen picture everywhere e
It sounds that the closed caption function is switched ON. Check the settings, and make it off.
11/11/2012 11:09:32 AM • Broksonic TV • Answered on Nov 11, 2012
Dvd player does not work
It sounds that the laser pickup unit to your disc player is either faulty or dusty. Insert a lens cleaning disc into the player, and play it for at least two times. If the fault is with dust or dirt, this must solve the problem. If not, make sure that the optical pickup unit is faulty, and should be replaced. Lens cleaning disc an be bought form most of the electronic spare part shops at your town.
7/21/2012 3:58:23 PM • Broksonic TV • Answered on Jul 21, 2012
Broksonic stuck on sleep mode
If a normal TV with a picture tube there is a short in the high voltage area or elsewhere---if a 13 inch or small set it will be less expensive to replace it than repair it.
6/11/2012 6:09:15 PM • Broksonic TV • Answered on Jun 11, 2012
Need a code number for this tv
depends what remote you got
5/9/2012 1:58:44 AM • Broksonic TV • Answered on May 09, 2012
2answers
I have a Broksonic model
since you have confirmed that the remote is working, then it means the problem lies with the TV.
There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
If the above is contrary to your question, please let me know and make your question very clear in the case.
Regards.
9/11/2011 5:02:40 AM • Broksonic TV • Answered on Sep 11, 2011
Broksonic TV Logo
91 questions posted
Top Broksonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Broksonic Televison & Video
Most Popular Question
dvd player not work
  • Televison & Video
