SOURCE: Epson LQ-1050 Matrix Printer Problem
I am getting my text cut off at the bottom what could be the problem
SOURCE: epson LQ -590 PRINTER PROBLEM
margins are set wrong, or there are special
formatting marks and/or characters at the end
of your documents.
START --> Printers & Faxes -> Chose printer -->
right-click --> properties --> ....
This sets the default settings, that are in effect every time
an application starts up.
Also note, that if printer settings are not listed within
your START menu, you can find them in the Windows
control panel. You can change what shows in the
START menu and what doesn't by right-clicking the
task bar.
the file menu:
File --> Print --> Settings ...
File --> Printer settings ...
File --> Page setup .... and also margins. etc...
This sets the actual settings for this application or the
current document. These settings over-ride the global
default setting in item (2)
reflect the way you use the printer the most often.
The settings in item (3) reflect the actual document you
are trying to print now.
reflect the paper in the machine, do not confuse
metric sizes: A1, A2, A3, A4, A5 ....
with English sizes: Letter, Legal,..... etc
These do not line up exactly.
are no extra characters at the end of your document:
Paragraph marks, Page Brakes, Form Feeds, etc.
Also check the paragraph settings (in Word for Windows,
for example, to make sure that is not the cause of the
problem.
In word for Windows, for example, you can also go
into tools, options and change the way your document
is displayed, such that all formatting marks become
visible (or click on the paragraph tool)
of print PREVIEW facility, so that you can see what
you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
SOURCE: epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
