Boot it into safe mode, and disable startup items, aswell as services within the msconfig window.
for most computers, you turn it on, and continue pressing F8 then the pc wil load, and if done correctly another screen will come up with multiple boot options, select either Repair, or simply go to Safe Mode, and once into safe mode, do the following...
Windows key + R > and this wil bring up a window called Run
then in that windows type: msconfig
within the msconfig window go to the services tab, and on the bottom check "Hide Microsoft services" and disable all startup services, next go to the following Startup tab.. and disable everything. now reboot your pc.
if you are able to boot now, then you have a problem with your os and you need to take it to an IT.
hope this helps
SOURCE: black screen on start up hp dv6600
have you check the display on external monitor, check it by connecting to vga port of your laptop,
if there is a display then its the problem of your laptop screen
SOURCE: NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
SOURCE: the please wait then welcome and stays at welcome.
1. Try to boot your computer in Safe mode and run a full system virus scan with your anti-virus software, this may fix the problem. The system will boot in safe mode only if its not a major damage to the file. If the system is not booting in safe mode, then perform system restore. Click start>all programs>Accessories>System tools>System Restore. Restore computer to a date where it was working fine.
2. In case the system refuses to boot up at all, then it is recommended to run a repair setup of windows Xp. To run repair setup, boot the computer with Windows Xp bootable CD and on installation screen, press R for repair setup. For detailed steps see http://www.windowsreinstall.com/winxppro/installxpcdrepair/indexfullpage.htm
SOURCE: Cant start windows
depending on where you purchased your laptop from, you could probably initiate the built in recovery using the F10 or F11
or hold ctrl alt and F9?
If this doesnt work then you will require a WIN VISTA CD, AMDN MAYBE USE THE repair OPTION?
Testimonial: "Thanks "
SOURCE: Can't turn on my VL760 netbook. It just "initializes."
As you mentioned the problem is above your control and it is hardware related issue, kindly go to the authorized service center, as it is a new net book don't do anything to you may loose your warranty.
Thank you.
