The dishwasher stops running and the "Intake/Drain" indicator flashes.
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I have the same dishwasher and it will not INTAKE water. This unit does ****. So much for a "smart dishwasher".
SOURCE: Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
SOURCE: drain intake indicator flashing. We have cleaned
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
