You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Western Digital's web site;
http://support.wdc.com/product/download....
Enter the drives model number in the search window. You want to do two things here. One, register the drive if you haven't done so.
Two, you want to download Data Lifeguard Tools. This software goes onto a floppy disk. You connect your WD to the system & boot to the floppy disk. The software will allow you to check the drive for problems & more importantly allow you to format the drive.
There are other perks you can turn on or off. These other perks can only be done with WD's Data Lifeguard Tools software. If you can not find this software on WD's site try the next link;
http://www.computerpi.com/wd.htm
Scroll down to the bootable floppy version. Use the downloaded software to create the partition FAT & (Remove any if present). Allow WD’s software to format the drive. You can choose your FAT too. Read about the software from the link above.
Once done, you should be able to boot to the windows CD & do a fresh install.
Here is the link for your board; (Biostar M7NCD Pro).
http://www.biostar.com.tw/app/en-us/mb/c...
Mike
The HDD wouldn't install XP in the original computer. I could install Win98 or ME. The XP install would return a similar stop message. I disabled all the disk and Bios caching as recommended for the particular error code with no better results. I used a different computer to see if the HDD was bad. The original HDD will not work currently either. The error message is that no FAT 16 or 32 partition exists. The HDD is still readable in the other computer, though. I removed all the extra boards (sound, TV Tuner, etc) and moved the original 512mb RAM back to the single location but got no improvement. I can't even boot into safe mode.
