XFX NVIDIA GeForce 8500 Graphic Card Logo
A
Anonymous Posted on Oct 09, 2013
8500gt driver - XFX NVIDIA GeForce 8500 Graphic Card
Driver for ge force 8500gt version 60.86.26.00.00
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Arbab Ahmed.
You need to go to www.nvidia.com for the driver for your Nvidia GeForce 8500GT.
Select your region.
Place your mouse cursor over "Driver Downloads".
Then click "GeForce Drivers"
Under the manual driver search menu select the applicable fields.
GeForce
8 Series
8500GT
Operating System
Language
Then click start search.
Take care!
How will i get the driver of my vga card. tell me how i will check its model. i don't know the model
*Its model was 8500T you can download it here: http://www.nvidia.com/Download/index.aspx?lang=en-us
*Make sure you select this option on the drop down menu list
Product Type: GeForce
Product Series: GeForce 8 Series (Since it is 8500GT)
Operatin System: Depends on your OS
LanGuaGe: Depends on you
Then click on search
*click on Download to Download the lastest driver :)
Thanks
1helpful
Ugrade Lenovo 8113 to GeForce 8500GT 512 -Problems?
Not a compatibility issues per se, but their could be a Driver conflict.
Install the Drivers FIRST, then power down, computer unplugged from power, observe Anti-Static precautions, and install the graphics card.
Plug the monitor into the graphics card, plug the computer into power, WAIT 1 minute, turn the computer on.
(The drivers are on the installation CD that comes with the Nvidia GeForce 8500GT graphics card. Just install the CD, and load the software. The drivers will automatically be loaded)
If you install a device first, (Such as a graphics card), Windows will break it's neck trying to find suitable drivers.
Windows will match up one of it's thousands of generic drivers.
Then you come along, and install THE drivers.
Driver conflict.
Windows: "Which drivers do I use? These or THESE?"
If you have already installed the graphics card, then powered the computer up, and installed the drivers, I suggest you do this;
Computer off, and unplugged from power. Open the computer case.
(I prefer to remove all cables to the computer, and lay it on it's side on a clean towel, on a table)
Observe Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
You may not even see it, or feel it.
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the open computer case, BEFORE you reach inside the computer, or take a device out of it's anti-static bag.
Should you get up in the middle of working on your computer, and leave, upon your return Touch the metal frame again ]
Remove the GeForce 8500GT.
Plug the monitor into the Integrated Graphics of the motherboard.
(VGA port
http://en.wikipedia.org/wiki/VGA_connector
Press the Power On button in, and hold it in.
Hold it in for a count of Five seconds.
(And I mean at least Five. Count 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
One of which is Integrated Graphics.
Computer case open, cables plugged back in, computer in normal position.
Plug the computer back into power.
When Windows has fully loaded, go to Start>Control Panel>Add/Remove Programs.
Remove anything you see associated with the GeForce 8500GT.
(DO NOT remove anything in the Windows files. It's a separate section you have to go into anyway, but thought I would warn you in advance, just in case)
Restart the computer. (Start>Turn Off Computer>Restart)
Once Windows has fully loaded again, install the software off of the CD disk, that comes with the GeForce 8500GT graphics card.
If you are asked to restart your computer - No.
Close all windows, go back to your desktop screen.
Shut your computer down normally.
(Start>Turn Off Computer>Turn Off)
Unplug your computer from power. Observe Anti-static precautions. Install the GeForce 8500GT.
Plug the monitor into the graphics card.
Plug the computer into power.
Wait 1 minute, turn the computer on.
Everything works okay, close the computer case.
Need to update drivers for Evga e-GeForce 8500GT
Hi:
The latest and greatest drivers for your card can be downloaded at www.nvidia.com
2answers
Monitor screen flashing and changing colors
This could be for 3 reasons,
1. the VGA card it self is not fixed properly on the slot,try removing the car & re pluging.
2. VGA card driver error ( uninstall the driver & reinstall the driver.) youcan download the laest driver from the follwoing link.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=8500GT-512&TypeID=en-us0000016
3. your VGA card has a defect. if you have warranty , take it back for a replacment.
HP Pavillion PC with Nvidia GeForce 8500GT freeze so often.
try enabling PCI option in the bios...
and also update your graphics card drivers for nvidia.com
Top XFX Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
