20 Most Recent
XFX GeForce FX 6800 (256 MB) Graphic Card Questions & Answers
I have another boring probleM0! my computer is
those beeps are actually codes telling you HEY something is wrong with me and that particular beep means there is something wrong with the display card so you should try to re seat your graphics card or maybe even check to make sure that you ram is good and in working condition
GeForce FX 6800 Graphic... Problem
you should look for updated drivers -
www.nvidia.com
If the problem persists, it might suggest a hardware problem.
It is a good idea to test the card in another machine and see if the same problem happens.(maybe in your friends computer ?)
Display cannot proper
hallow there ,i had the same problem ,,,,,this happens when your 3d cards due to over heart gets burst,so the computer will not start and it will show you a problem .... the 3d card gets burst if you kept the system on for a long time ,or due to flaktuation ,,,,,,
now to start the computer ,remove the monitor wire from the 3d card socked { the monitor wire will be attached to the 3d card remove from it and attach it to the motherboard socket }
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some.
1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!)
if not then
2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try
Well if that doesn't work, tell me more!
Regards,
Armando
Black screen
try starting in safe mode, by pressing F8 when the computer first starts up keep pressing it, click, click, click not holding. then goto display setting in control panal, and change your monitor type, if you can't find your monitor listed use a defult 800X600 one. it sounds like your monitor is not capable of displaying the resolution xp wants to use.
Adaptor settings
Take out the video adaptor that you have installed and see if you can boot up with only the on-board video, first in standard mode and then if it won't work, try the safe mode..
Did you change any other settings?
Also, when you had the video card installed, did you disable the onboard video?
Black screen
lol thats was dumb for him to tell u that maby he ment reinstall it not disable it go in safe mode f8 enable it again
My video card matrox g450
You need to upgrade your graphics driver,
Start in safe mode and uninstall graphics driver from device manager. restart the computer, and install new ones..
OR
go to BIOS and enable the graphics card, if it is an additional card.
Nvidia 6600 256 mb agp
Check the temps of your card using rivatuner and the cpu with speedfan to see if they are overheating.
Are you running either overclocked?
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
No sound xfx one
You must set up port in drivers and in windows
analog for speakers and headset, or
digital for hdmi to tv speakers
