Inverter KEB COMBIVERT F5 Logo
harvin largacha vidal Posted on Oct 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power unit not ready - Inverter KEB COMBIVERT F5
mntech1
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Inverter Expert 120 Answers
  • Posted on Nov 26, 2013
mntech1
Inverter Expert
Level 2:
Mentor:
New Friend:
Answers
120
Questions
0
Helped
78153
Points
186
Do you mean no_Pu error?
Reason for error = 24Vdc is being applied to the control card but the mains voltage is not being applied to the power stage.
  • Marwan mourad
    Marwan mourad Oct 14, 2022
    So what i have to do exactly?
sutrisno
Level 1:
New Friend:
  • Contributor 1 Answer
sutrisno
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1949
Points
Hi,please you can show picture keb for power unit,or maybe you have another solutions
  • sutrisno
    sutrisno Nov 26, 2013
    we have problem in type:23F5H3R-940A
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Samsung PPM50H3Q 50 in. HDTV-Ready Plasma will not power on.
could be a power supply failure or a control issue. I would take the unit to a repair shop and see if they can provide you with an estimate. You could try to buy a replacement power board and install it on your own if you are mechanically inclined.
http://www.shopjimmy.com/samsung-bn94-00494u-power-supply-unit.htm
Screen went black and power light flashing on a Toshiba Plasma 42HP83
MAYBE POWER BAD POWER UNIT PART NO:
Manufacturer Toshiba Part Number 23122442 Description POWER UNIT ASSY, P
Have a 155000 btu ready heater
It sounds like the unit is tripping the breaker because the breaker is not rated high enough to handle the heaters power usage! If its not that then it may very well be the thermostat needs replaced in unit!
Test at a friends house to see if its your system or the unit!
1helpful
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
2answers
Not saying "ready to brew"
Had this same problem. the "not ready" message flashes, unplugging the unit, pushing the power button have not impact ont he message. Keurig tells me this is an indication the heating element has burned out. I had ot call in a warranty claim and get a replacement.
Maxent MX-50X3 50 in. HDTV-Ready Plasma
Yes I had this problem. Unplug the power cord for 1 min then plug it back in. The tv will reset and the buttons then work again.
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
