20 Most Recent Vivitek D825MS Projector Questions & Answers
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
Vivitek D825MS... | Answered on Feb 05, 2016
By 9 blink it means the color wheel inside the projector is faulty. To rectify the problem you have to open the projector. First of all you have to to clen the color wheel if it dosen't help then you have to replace the colour wheel of the projector
Ajin
Vivitek D825MS... | Answered on Feb 10, 2012
The Vivitek D825MS Projector does not have any speakers of its own. You have to use an outside source for sound. Another set of speakers connected to the laptop might help, or if you have access to a plug in through a stereo or mixer to take the sound from your computer to the speakers hooked up to the stereo or mixer, that is ideal.
Hope this helps.
Vivitek D825MS... | Answered on Oct 18, 2011
Hook up using the S-Video port, the VGA port, RCA port, or the RS-232 port. The USB port is not used for input on at least some of the Viviteks as per Vivitek Service"The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service"
Hope this helps.
Assuming that you have all the connections between the laptop and the projector already performed, you should check in you laptop's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
If even with these indications you are still not able to make your laptop show its information through the projector, please send us more details on how you connected your laptop to the projector, as well as the brand and model of your laptop.
Hope this information can help you!
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Vivitek D825MS... | Answered on Mar 11, 2011
1 Check the cable for damage
2 make sure the settings are right in Display Options (second monitor is enabled)
3 check computer is set to the resolution that your projector can display (start of the lowest)
Vivitek D825MS... | Answered on Mar 09, 2011
If this is the first time you've ever tried to project something from the laptop you probably just need to activate the laptop's data port. Look for an "f" key across the top of the keyboard that says CRT/LCD, or has an icon showing 2 screens. While holding down the function "Fn" key in the lower left corner of the keyboard, press the correct "f" key. You may have to do this a couple of times because it goes in a cycle where the image is on your laptop,only, next time on the screen, only, then on both the laptop and screen.
Vivitek D825MS... | Answered on Jan 13, 2011
I don;t know the vivitek projector, but I have worked with 100s of models overall. This type of message usually comes from a bad selecto=ion of input or signals that are out of range. With a Mac, I'm guessing that you are connecting with either VGA or DVI. Verify that there are no switches that control the input connector first of all. Second, verify the resolutions that the projector will handle and make sure that you are within that range. If neither of those help, try and post the input connectors etc for your specific projector. I'll try and locate info as well.
Thanks,
Dan
Vivitek D825MS... | Answered on Mar 30, 2010
Vivitek D825MS Projector Logo
25 questions posted
Top Vivitek Office Equipment & Supplies Experts
Lawrence Oravetz
Tom Chichester
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Vivitek Office Equipment & Supplies
Most Popular Question
connect
  • Office Equipment & Supplies
