The espresso portion may be clogged with hard water deposits, and the steamer tube with casein. Run a tank of plain white vinegar a couple of times then run a couple of tanks of plain water to flush the vinegar, Open the steam valve while the espresso portion is running and set the steamer pot under the steamer. Don't be surprised if a long white tube of hard white material slides out of the steamer valve. That's the casein, actually a form of organic plastic.
SOURCE: Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
SOURCE: how do I get my breville cafe roma espresso
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
