Fisher paykel GWL10 doesn't drain Previous problem may be connected: When washer was filling with water it was screeching. Taking off the washer hoses turned up that the cold water screen had been pushes aside and sand-like particles were on the inlet valve entry; I cleaned off and the screeching became intermittent, more frequently on regular load, but didn't totally disappear. I noticed a grinding noise when moving the tub like it was rubbing on sand when I moved it back and forth, there was dirt (sand?) on the tub ring. I figured the sand would wash out over time. After 2 previous washes completed OK, the last wash stopped at rinse cycle and didn't drain. Moved up to spin and still didn't drain. Shut off machine, restarted at rinse, walked away and when I came back machine had shut off still full of water. I restarted at rinse and noticed a low humming as if it was trying to drain but couldn't. I shut it off. The diagnostic mode instructions confused me - one said that only the LOW on the water level should show after pressing/holding Temp button (down or up), the other that only HOLD on spin should show before using spin (up or down) to have hold and slow show on the spin to get the diagnostic code. Initially I got LEDs left to right: 0 1 1 1 1 1 0 1 (1= LED, 0= no light) and the last (spin) LED was blinking RED. I couldn't find a code in the listing that I have. I then presses/held Temp up & power and got the hold only LED on the spin speed and the with the buttons until I got the HOLD. The default code now is 0 0 0 0 1 0 0 1 with spin RED but not blinking. According to diagnostic this is a machine size error. I reset the size, as instructed, with hold/press TEMP up & Power to get to HOLD on spin, then pressed Power. Yet, I still get the same diagnostic code indicating size error. I unplugged machine and reset twice but get same code. Is there another way to reset the machine size so I can get the diagnostic code that I need about the not draining problem? I think the problem is the pump because the "hum" seems like the cycle tells to drain but it can't. What is the best way to check if the problem is a clogged pump (because of the previous sand issue)? I replaced the diverter 4 years ago when I had a similar "no drain" problem. Could it be that the diverter is defective again? The original diverter worked for 9 years. thanks for any suggestions.
Easy to check the pump but you need to have a bucket handy. Tilt washer backward pump will be on the right side. Remove and clean. Watch out for the water!
Posted on Sep 26, 2013
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Oct 15, 2013 | Fisher and Paykel IWL12 Top Load Washer
Feb 27, 2011 | Fisher Paykel EcoSmart GWL15
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Dec 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Dec 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Nov 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Mar 29, 2008 | Washing Machines
Sep 16, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
74 people viewed this question
