Fujitsu Siemens LifeBook S6120 Notebook Logo
marvin romero Posted on Sep 01, 2013
How can i find the mac address of s6120 - Fujitsu Siemens LifeBook S6120 Notebook
Jonathan Hwang
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 01, 2013
Jonathan Hwang
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
345
Points
26
1. Click the Start Menu
2. Click on "Run"and type in cmd
3. Type in ipconfig /all
4. If you find your connection, it should say Physical Address!
-JH
How to change V800R006C02 SCUB mac-address on Huawei MA5683T/MA5680T?
You can change mac-address of SCUB on Huawei OLT MA5680T in following way:
1. First you have to login as root user
2. You will have to enter in diagnose mode with following commands:
huawei(config)#diagnose
huawei(diagnose)%
3. you have to check which mac address is currently in the system by command:
huawei(diagnose)% display sysman mac-address
Current MAC address of active mainboard: 0025-1c54-c45c
Default MAC address of active mainboard: 0025-1c54-d0763
4. Changing mac-address you can done with command:
huawei(diagnose)%sysman mac-address current 0025-1c54-c455
Command:
Modifying current MAC address may cause the conflict of MAC address, are you
sure?(y/n) [n]:y
5. Last step is to reboot board on which you have change mac-address or to reboot system. In this way new mac-address will be applied to the SCUB board
Lifebook s6120 does not start - dead i can't turn it on do i have to clean the motherboard or something else plese help!!!
unplug from the power and also take out the battery.
now hold the power button down for 30 seconds.
put the battery back in and hook up the power and try to power it on again.
How do i add the mac address of my printer to the list of permitted devices
Disconnect the Ethernet cable between the router and the cable-modem (or DSL-modem).
Access the web-interface inside the router.
Allow "all" MAC-addresses to access the router.
Turn the printer off.
Turn the printer on, so that it gets a "fresh" IP-address from the router.
On the router's web-interface, get it to show a list of the "active" DHCP-connections.
It should show the IP-address and MAC-address for your printer.
Copy that MAC-address, and the MAC-address of your computer.
On the router's web-interface, access the table of "allowable" MAC-addresses.
Add the two MAC-addresses.
Enable the "selected MAC-addresses only" option.
Reconnect the Ethernet cable.
1helpful
When i want to install windows it doesnt show mine hard drive. i lookd in bios but it says none,i tryd to replace the hard drive but still nothing. mine laptop is an fujitsu siemens s6120. hope u have...
Make sure that the HDD connector are connected properly.
The power connection are OK? Set the BIOS as default and check.
Please post your feedback and Vote if the problem resolved as per your satisfaction
2answers
How to change mac address?
Every Ethernet card has a MAC address burned-in at the factory. At times, you may want to change this MAC address to one of your own choosing.
The procedures to change a MAC address are specific to each operating system.
How to change a MAC address in Microsoft Windows Under Windows, the MAC address is stored in a registry key. To change a MAC address, find that key with `regedit` and change it. Of course, Microsoft keeps moving the location of the key around!
Windows XP adds an option to change the MAC address on some network cards under the Advanced tab in the network adapter's Properties menu.
A much easier and more reliable method to change a MAC address under Windows is to use a software utility program designed to do this for you.
Macshift is a free utility that you can use to spoof your MAC address under Microsoft Windows.
How to change a MAC address in MacOS Instructions for changing the MAC address on a Macintosh can be found at MAC Spoofing on the Macintosh.
How to change a MAC address in FreeBSD In FreeBSD, you can change your MAC address with the `ifconfig <interface> link <address>` command.
How to change a MAC address in Linux Under Linux, you can change your MAC address with `ifconfig <interface> hw <class> <address>`, or you can use the GNU MAC Changer.
How to change a MAC address in Solaris In Solaris, you can change the MAC address with the `ifconfig <interface> <ether> <address>` command.
How to change a MAC address in OpenBSD OpenBSD does not, by default, allow you to change the MAC address. It is possible to change the MAC address under OpenBSD with sea.c.
How to change a MAC address in HP-UX Under HP-UX, you can change the MAC address in SAM by selecting Networking and Communications, then selecting the interface, then Action, Modify, Advanced Options. HP-UX refers to the MAC address as the "station address".
Changing a MAC Address in Hardware Speed Demon Adapters sells network cards which give you the ability to change the MAC address stored in their EERPROM.
This can give you the ability to change your MAC address under any operating system that supports either the PCI bus or PCMCIA Type II cards.
My wifi wont work. I dont have the driver. the ones i downloaded wont drive it. pls give me a hint on what to do? I use lifebook s6120 fijisu siemense
There are some wireless drivers at the bottom of http://www.drivershq.com/Drivers/Fujitsu-Siemens/Lifebook/S6120/24971/45495/48955/Drivers.aspx
S6120 didn't take 250GB memory
hi Barch
every processor has three types of buses.
  1. address bus
  2. data bus
  3. control bus
The size of address bus is responsible for the number of memory locations a processor can access.
The size of address bus is fixed for each processor.
Your processor can address that many memory locations only through its address bus.
That is why anything more than the limit of memory location is waste.
Thank You
3helpful
User guide needed for lifebook s6120
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. Here is the manual / guide:
http://www.fujitsupc.com//www/content/pdf/usermanuals/sseries/S6120,S612D_GINGER_USERGUIDE.PDF
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
MAC ADDRESS
- You have to set the Mac Address value after exchange PCB Assy.
(only Bluetooth product)
1. Disassemble the YP-T10 case and Find the MAC Address. (12 digit)
2. Open “memo pad” and write Mac Address on it.
3. Save “BDADDR”
4. Connecting USB, Copy “BDADDR” into Root.
5. To confirm Bluetooth Mac Address
- Power on
- “Setting – My Device Info – View the MAC Address”
6. If an error occurs, the address of the error is saved in
the ErrorMac .txt file as text
7. Mac Address Setting is done.
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
