20 Most Recent
Fujitsu Siemens LifeBook E4010D Notebook Questions & Answers
Fujitsu ifebook ah 77/G drivers
Guide for future;1) Fujitsu Support >
http://www.fujitsu.com/us/support/Under the bold sub-heading - Product support for:,left-click on - Notebooks and Tablet PCs - in the list.2) Down under the bold sub-heading - Product Information -,left-click on - Downloads - in blue.3) At the top left under - Select Product -,left-click on - Notebook4) At the top middle under - Select Series -,scroll the sidebar down, click on - E Series5) At the top right under - Select Model -,scroll the sidebar down, left-click on - 4010D6) Go to the right, click on Go. (To the right of the white arrow in the red box)Remember,...you need to download AND install the driver/s.Need info on how, post back in a Comment.Regards,joecoolvette
I cant open internet explore and yahoo massenger
To remove only eType's promotion link:
Enter eType's Settings window> Advanced tab and uncheck: "Help keep eType free by sharing with your friends".
To uninstall eType completely:
Enter Start menu> All programs > eType folder and you'll find the uninstall link under eType.
For more details and print screen, see Q 5.14 at www.etype.com/help/faq/configurations/
Brocken
Sell it for parts on ebay!
Please leave me a good rating, thanks! :)
I bought an old Fujitsu
It looks like the hard drive is a 60Gb ATA 5400rpm 2.5" type but there is an adapter that you possibly haven't got.
I appears that I have problems with the battery
short battery life is contributed to these, 1. Old battery 2. Lots of apps running in the background 3. Taking lots of photos 4. Charging the phone when it does not need a full charge 5. Leaving your phone in direct heat or cold 6. Dropping the phone 7. Leaking battery 8. 1 year or more old battery 9. Continuously talking and charging at the same time 10. Ensure to contact your insurance to see if the battery is protected under your plan.
Fan doesnt stop on my e4010d
It is quite possible that the fan is clogged with dirt mainly fibres/textile fabric or hairs . This makes the processor heat up as there is no ventilation and cooling., thermal sensor is active. It will be best to remove an clean the vent of the fan and reset to solve the matter.
Changing/reset CMOS Lifestyle S6410 fujitsu-siemens notebook?
Here is the link from where you can download Bios Flashing software according to your BIOS.
http://www.biosman.com/bios-flash.html
Download the software according to your BIOS.
your system BIOS is not available for download in the Fujitsu site.
you need to confiremed your BIOS Chipset manufacturer name with current BIOS version.and Check the upgrade version in the chipset manufacturer site only.
Note: Fujitsu doesn't recommend BIOS upgradation.
Port replicator
Are you using an original port replicator or a third party one?
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps.
in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
