20 Most Recent
Fujitsu Siemens LifeBook S7020 Notebook Questions & Answers
Please help. My Fujisu Lifebook
It seems you have a problem with your power adptor, which gets easily broken wires, due to usage. If you have a multi tester and possible if you can check the output voltage of your adptor, which should give 19 vdc according to the requirement of your laptop. Try to get power adptor of same kind and check, if it does work, repairs can be done to the power supply, if you can find a tech for this.
How do i get to
remove rhe 2 screws which have arrows pointing to them either side of battery and screws underneath battery, remove top cover with speaker grills and power button, remove 2 screws at top of keyboard, remove keyboard, if you want more access, remove rest of covers, screws, dvd-rw and screws beneath dvd-rw gently prise casing apart, remove screws from mobo, remove mobo.
I don't have fujitsu siemens
Well you did not state your operating system type. Try this downloading the drivers at this url: http://hotfile.com/dl/113988251/2c20f9d/s7020_21_audio_xp.zip.html
OR
If it doesn't work, specify your operating system so that I can get your specific drivers
How to reset bios password
IF you have your bill of sale, a good local shop can reset the password but it will still cost you. At least you avoid the shipping and maybe it will be less than $100.
Programs that reset passwords are expensive to buy, IF you can find them. Otherwise, yes, you have to send it back to the manufacture who will do it for around $100 plus shipping.
I have a Fujitsu Siemens Lifebook s7020 with no
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
No sound from built-in speakers
This is because of the Operating System XP as there are no drivers for the inbuilt speakers.Install Operating System Vista and im sure it will work after that.
Regards
Reset the BIOS password
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it by pressing F9 or F12 and use BIOS / CMOS Tools from it.
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps.
in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
