Fujitsu Siemens LifeBook C1020 Notebook Logo
Question about Fujitsu Siemens LifeBook C1020 Notebook
Disassemble fujitsu siemens lifebook c1020 to replace motherboard
In fact it is the power jack that is at fault but this is attached to the motherboard so I need to know how to take it apart
  • Anonymous Jan 04, 2010
    If I could find a manual to download I would do. I've looked for one with no luck. Fujitsu only provide users manuals. Any idea where I can locate a service manual?
Anonymous
  • 83 Answers
Try downloading a maintenance manual.
they are quite helpful.
Posted on Jan 04, 2010
How do I restore the built in keyboard on my Fujitsu Lifebook C 1020
You need to take apart the laptop to do this.
Why not simply attach a portable USB keyboard which will work just as well?
Enter key does not work at all!
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one
1helpful
Replace the power in socket on lifebook c1020
i took apart a dell and was having the same problem. on mine it turned out to be double sided tape and it pulled right apart. but you should check, check and recheck for screws before you just yank it apart
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
My laptop doesn't turn on and the red indicator of the battery
check the power settings and make sure that the battery and power cable settings are on when plugged in. Also sometimes a battery needs to be installed to do this. If the power adapter is working then all should be fine.
1helpful
3answers
Fujitsu LIFEBOOK C1020 power problem
or a bfoken powr jack.I replaced mine recently for £4.00 and took approx 2 hours.
Top Fujitsu Siemens Computers & Internet Experts
Narseman
Rob Hill
Rob Hill
George Etukudo
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
