SOURCE: RHD to LHD conversion
A company called Flying Spares in Warwickshire will be able to supply all the parts. I'm not sure if the steering box is part of the subframe assembly on these models, if it is, you'll need a new subframe setup & new stering box, but the rack is reversible I think and the steering column isn't a problem. 01455 292 959. Ask for Ben, tell him Dave Flora gave you the details. Good luck
SOURCE: how can i convert my 1996 toyota 4runner from lhd
that would be a lot of work and requires a lot of time and money if you don't have the right equipments.
modifications like that can be done but hard.
imagine almost all the parts along the dashboard will be placed on the other side.
lots of parts might come thru where the steering assembly will be placed.
that's a lot of work.
large payment if you let it be done to modification shops.
SOURCE: Hi, I just bought a RHD 1995 European Accord Sedan
allmost everything
the dash the steering column the wiring harness the pedal brackets, the pedals very expensive to change it
you will probably need to change many things under the hood as well such as the steering linkage and steering rack, power steering lines and many other things
your looking at spending more than the car is worth
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
