I had a similar problem, the middle cylinders- both compression was low. The Expert Mechanic told me that the valves have to be replaced. So the Head was opened and the valves were checked and they wer allright. The the Head was machined, and the PISTON rings were replaced. Now the vehicle runs good. This might help.
So when you get to replace the valves, be ready for the pistons/ or piston rings. cost about 600 dollars in all.
It
can be low fuel pressure issue or clogged fuel pump. Or its engine related
issues,---------------
Check
the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota
Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota
Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at
idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and
runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota
4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine
stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These
details will help.
Thanks.
Driving?
issues?
Vehicle starts then stalls and shutdown?
This will help.
Thanks.
Is it fuel injected?
