SOURCE: the wires going to the voltage regulator keep burning up.
Common problem with poor quality parts, the regulator is the problem, the generator is working other wise you would not have fried the wiring, you answered your own question. someone telling porkies to get more money from unsuspecting client?
The regulator controls the voltage not the generator, the generator only supplys the voltage it cannot overcharge unless the regulator is not working properly, simple!
SOURCE: ALTERNATOR TO VOLTAGE REGULATOR WIRES MELTING ?
would mean circuit is over loaded/shortted
check diode pack for polarity and battery
SOURCE: are the two wires coming out of our power
The voltage coming out of your alternator is AC voltage and has no polarity like Direct Current does. Therefore no positive and negative. Two of the wires should be formed into a plug or they'll be smaller and shorter than the other wire. These connect to the connection at the engine case. The larger gauge longer wire goes directly to the battery positive terminal.
