The first problem when connect the battery polarty wrong happend cgarger fault i solved this problem after two days this massage appeared rectifire internal fault
Did you check the power regulator? It can 'collapse' under a load, while it looks perfect when measuring the resistances.
Does your rectifier have cooling fins?
this is a multimedia phone having much features, if you are using this phone for listening songs/video then backup of one day is ok but if the condition is in normal usage (normal phone calls and some songs)it mean you have to replace your battery for long backup but before that try to reset your phone with factory settings. (battery consumption is also based of network strength,bad network **** the battery in a fastest way) if every thing is correct then go to change battery connector.
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
sir go to the link elektroda.pl 1 open the supply, 2 check the ac voltage upto rectifire a 3 check the further dc voltage after the bridge rectifire
for 1 see if the ac is going upto rectifire if not then remove the fuse that is covered with tape or if there is a resistance fuse , then take it out and replace
remember to change the fuse with similar value 2. if dc is formed, check the filters and the diacs and diods in post sm transformer circuit
else write me again
if u solve the problem then thank me else send me internal picture
the rectifire in the alternator is not good,it that which control the voltage, u must replace the rectifire,and possibly the regulator is not working in the alternator
Your camera has a built in diagnostic computer. When Nikon gets the camera it connects the camera to a computer to checks for faults much like modern day cars. There is nothing you can do other than try another battery or send into Nikon. Batteries like camera can be bad.
