Motorola Mobility RAZR V3 Logo
Posted on Sep 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check sim is displayed??
Check sim is always displayed on the screen and when i press any key it shows "emergency call only".when i switched off my phone and switched it on again the phone worked well but after a minute or so was back to the " check sim" screen
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Feb 22, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1416235
Points
13016
You phone firmware needs to be reflashed any mobile service center should be able to fix that problem for you.
2answers
2answers
I bought a sharp 903sh online through YesAsia. On my pc it shows up a sx833. I can't make or receive calls but it will send and receive texts. System sounds eg text arriving,are fine but the voice...
Dear Amaxeen ,
Well It Seems the configuration problem ,you should have to configure your phone properly for that ,if you wanna to use its aal features you need to download proper drivers and manual ,so that you can use it smoothly.
You can download all stuff for your Sharp 903 , from this link:
http://www.sharp-phone.com/country/downloads/downloads.php?country=GB&lang=en&product=903
Cheerup and Be Happy Always
Mar 07, 2008 • Cell Phones
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
22helpful
2answers
Sir my spice M-5170 ther is network problem in this mobile no service & emergency show on display after insert the sim card.
sir my spice M-5170 ther is network problem in this mobile no service & emergency show on display
6helpful
Even after hard formatting the phone memory, my phone's displaying : "not enough memory to delete SIM messages.Delete some data first." plz guide me regarding the plan of action....
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Sciphone on messaging it randomly presses letters
After inserting my SIM card, switching on the phone, "Insert SIM" is displayed and when trying to make a call, the message "Emergency call only" is displayed and
Dec 26, 2009 • Cell Phones
1helpful
Sim not valid
you will have to go to whatever provider that your sim belongs to and have them validate the sim card for your new phone
hope this helps
Is there a waay to lock the keys while it is in my purse?
this should help you out.
Basicall press MENU > *
Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
3answers
Bought used sim card for Blackberry rim 7520
the phone number should be retrieved from the sim card or carrier login procedure.
I had a few blackberry's, including a 75xx series one, and when I popped in another card (I have a couple of prepaid subscriptions for testing), the number always came up automatically.
Should work... If not, try contacting RIM/Blackberry support, but I doubt they'll still give support for the 7xxx series models... sorry
3helpful
My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
