When i turn on my tv, First it make a buzzing sound , then the power button start blinking 6 short blinks followed by a pause of 3 seconds,And it repeats. 1 long blink of 3 seconds to finish the sequence. I hear the sound of the tv . Then the sound goes out, But there no picture at anytime. Help, Help Please !
SOURCE: Actually Philips 20PF5320/01 Fault no power, blinking LED
If the TV has sound and no picture, it might be the timer settings. There is a fix for Philips 20PF5320 here
http://www.123datarecovery.co.uk/fix_philips_pf5320.htm
SOURCE: tv fix
that is usually related to the LSB large signal board will eventually need replacement. Most repair shops will not troubleshoot the LSB at component level, they will opt for replacing the entire circuit board. If you need more info or help to locate a LSB board. please let me know.
contact www.wehavepart.com 1-800-575-9833 for the part and see how much it cost. Or www.advancebaldwin.com or www.andrewselectronics.com./
SOURCE: blue,red,green lines on top of screen for couple months. Now tv wont work.
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
Dan
SOURCE: Power light comes on, then blinks 6 times, then off for 2-3 secon
You need a new Naftakey bord part number 313501707611.
Its your volume, channel and your on and off button that needs to be replaced you can do this yourself. Remove the front cover it just pops out and unscrew the back cover disconnect the wire to this area on the part it self it states "part number and name". Good Luck, in getting this part. Im having trouble in getting this part (discontinued item) They may have under another name part.
