I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
I need a service manual
