I need user guide for the sony ericsson MW600
You may download the extended user guide at http://www-support-downloads.sonymobile.com/mw600/userguide_EN_MW600_1236-6504.1.pdf
SOURCE: my sony ericsson mw600 is
If there reset function does not work then there is a serious fault in the memory or there is a damaged board . It is possible that in such cases there willnot be any communication and can be a serious fault on the board.
So If you are not able to detect the headset player on your Phone or that the bluetooth does not come active at all then the unit is damaged and you must take consensus with the service center.
There is not much to be done if the board is faulty but it is worth to take an opinion before you further damage the device , in case the unit can be opened and the main board restored after a full reset fom within or if there was a case of moisture build up within that had caused this fault.
Thank You for using FIxya.
