20 Most Recent Sony Ericsson MW600 Stereo Bluetooth Headset With FM Questions & Answers
Hello People! I Fixed my MW600... :D WHAT HAPPEND? - I was listening music and it fell from my arm for the chair, about 30cm height and after that, it not power again... HOW I FIXED IT? - I had to disassembled it. I had to remove its battery, spinning a little the battery and put its back. I pushed the power button and it worked... :D Follow this video, step by step, for disassembly the mw600. https://www.youtube.com/watch?v=UyEC33sUS_4 Please, be careful!!! Good Look!
Sony Ericsson... • Answered on Apr 04, 2014
Below solution from talk.sonymobile is perfectly worked for me. Please try this:
i got the same issue and i have to fix it myself. Here is the step: 1. Under the female micro usb has a "small black plastic film" was glued to cover a "s c r e w". pull this film out. 2. "S c r e w" out this "s c r e w", pull out the bottom cover of the WM600. note: keep your eyes on the plastic power button, dont get it lost. 3. Look care fully inside u will see the battery, there is a small gap between the battery and it cover, use tool like tweezers to separate the battery and it cover a little bit. after that the WM600 will turn off. 4. tied everything back to its original 5. charge it for a while and then press power button to turn it on. if you got any problem of my ideas, leave a comment, i will attach the pictures for each step. Sorry for my bad english. Good luck.
Sony Ericsson... • Answered on Dec 04, 2013
Because ur is physically damaged internally , Buy the new one
Vipin
Sony Ericsson... • Answered on Jan 31, 2011
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
Sony Ericsson... • Answered on Dec 02, 2017
Sony Ericsson MW600 Stereo Bluetooth Headset With FM Logo
Popular Tags
33 questions posted
Top Sony Ericsson Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Radio Communications
Most Popular Question
need user guide mw600
  • Radio Communications
