The Blomberg was in the house and has been working well for over a year. Today it refuses to start. The panel lights up, I can change the program but when the door is closed it won't start the cycle. Normally the motor would start to drain any water left in it. Not now. Any suggestions? I do not have the schematic. I could troubleshoot the electrics if someone can provide it
SOURCE: PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
SOURCE: Candy CDI1012 Integrated dishwasher. When I
Hello mm1973,
It could be because of bad door latch switches / blown thermal fuse / blown or oversensitive control board. In all these scenarios, a dismantling of the machine is required. If you have no prior experience, I'd recommend getting a professional to diagnose/service it.
Try these checks too:
Hope that helps!
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
SOURCE: Dishwasher won't drain when cycle
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
