20 Most Recent
Blomberg DWT14210 Questions & Answers
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Blomberg...
Answered
on Jul 09, 2015
Model LDV42244. What caused salt and rinse aid lights to turn on?
Your Bloomberg dishwasher has a water softener system built in. This should not be ignored. Dishwasher detergent tablets do not take place of water softeners. The light indicates dispenser is empty. It is up to you to fill these dispensers. A rinse aid is not always necessary but hard water can ruin a dishwasher.
Blomberg...
Answered
on Dec 28, 2020
Blomberg dishwasher door falls open, no resistance to the floor
Blomberg machines are special. The insulation and access to side parts are concealed. The dishwasher is encased in stainless steel panels, so you actually need to totally disconnect and remove your d/w for this repair. I bought the little parts, nice and cheap, but I am not going to uninstall and reinstall the entire unit for this little inconvenience. I am going to fashion a swing-down door prop instead.
Blomberg...
Answered
on Aug 15, 2019
My Blomberg dishwasher will not
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Blomberg...
Answered
on Mar 25, 2019
