LCD Thomson 32LB040S5 It turn on but the sound is always in high volume and i cant control it.
I assume you have already tried using the buttons on the side of the TV to adjust it? I would just do a factory reset on it. Enter the TV main menu. Select factory reset to return the TV Menu settings to the factory default values. If this does not fix it unplug to TV for 45min to do a complete hard reset.
SOURCE: I have a LCD TV THOMSON 32lb040s5, the problem is
you probably have a fault on the stand by power board.
this normally requires soldering and maybe some componet changes. This is not a job for the unskilled. best carried out by a service engineer(shock hazard)
there is a service kit for this available from tvs-services.com 012453925
I think it the mainboard but will be the chip sound or microprossessor?
