I have a 97 ford windstar van that has any array of symptoms. but what would really help is a printable picture of the fuse map with the component designation. then I can talk about the transmission, abs and service lights, lack of power to the radio and the smell of coolant when I turn on the defogger but never loose coolant. thanks
Todd Fields,Maui
Your owner manual sould have fuse chart. Some fuses/ekays in enine compartment. Some in car on left side of instrument panel
in car
Fuse
Amps
Circuits Protected
Power Mirrors, Anti-Theft Warning Light, Diagnostic Connector
Generic Electronic Module, Start Interrupt Relay Coil
Radio Illumination, Remote Radio Illumination, Electronic Instrument Cluster, Electronic Instrument Cluster PRNDL Illumination, Electronic Instrument Cluster Switch Module, Analog Cluster Illumination, Instrument Illumination
Not Used
5
Not Used
6
15
Rear Quarter Windows (LH and RH)
7
15
High Mounted Stoplamp, Brake Shift Interlock
8
25
Subwoofer, JBL Amplifier
9
10
Park and Turn Lamps, Side Marker Lamps, License Lamps, Stop Lamps
10
High Beam Indicator Electronic Cluster
11
15
Park Lamps
12
10
Remote Radio, Auxiliary Warning Lamp Module, Remote Keyless Entry (RKE) Module, Anti-Theft Controller Module, Radio Illumination
13
15
Radio, CD Disc Changer
14
5
Electronic Chromatic Mirror, Analog Cluster Indicator Lamps, Air Bag Module
15
Not Used
16
15
Horns, Horn Relay Coil
17
15
Fog Lamps
18
25
Front Wiper Motor, Front Washer Pump, Wiper/Washer Relays
19
10
Generic Electronic Module (Pin 57), Electronic Instrument Cluster
20
25
Integrated Relay Control Module, Ignition Coil
21
10
Air Bag Module, Rear Window Defrost Relay, A/C Clutch, Temp Blend Door Actuator, Brake Shift Interlock
22
20
Rear Cigar Lighter, Power Plug
23
15
Multi-Function Switch
24
20
Rear Wiper Motor, Rear Washer Pump
25
10
Turn Signal Lamps, Instrument Cluster Turn Indicator
26
15
LH Aero Headlamp, Left and Right Trailer Stop/Turn/Hazard
27
15
Hazard Warning Lamps, Instrument Cluster Turn Indicator
28
15
Instrument Panel Cigar Lighter
29
15
Battery Saver Relay, Interior Lamp Control Relay, Interior Lamps, RH and LH Keyhole Lamps
30
25
Backup Lamps, Electronic Cluster
31
10
Rear Air Suspension
32
15
RH Aero Headlamp, Trailer Park Lamps
33
15
Anti-Lock Brake (ABS) Relay, Anti-Lock Brake (ABS) Module, Daytime Running Lamp (DRL) Module
34
30
One Touch Relay, LH Window Motor
35
15
36
30
A/C Mode Switch
37
20
Door Lock Actuators, Memory Door Lock Relay
38
15
Heated Mirrors (LH and RH)
39
30
Auxiliary Blower Motor, Ref. Valve Solenoid
40
30
Window Motor (RH)
41
5
Autolamp Relay Coils, Autolamp Sensor
42
43
44
please rate as fixya if this is what you need.
under hood
POWER DISTRIBUTION BOX
Location
Name
Amp
Circuits Protected
A
Trailer Tow
50
Fuse 32/Fuse 26/Electric Brake
B
Fan (Hi)
60
Cooling Fan (CCRM)
C
Start
60
Starter Solenoid/Fuse 30/Fuse 36/Fuse 2
D
Ignition
60
Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33
E
Rear
Blower/
RAS
60
Rear Heater Blower Motor
Rear Air Suspension
F
Seat
60
Power Seats
G
Not Used
H
Fan-Lo
40
Engine Cooling Fans
J
Power Accessory
60
Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19
K
Light
60
Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17
L
ABS
60
ABS Control/Pump Motor Module
M
Heated
Backlight
60
Heated Backlite/Fuse 16/Fuse 28/Fuse 22
N
Fuel
20
PCM/Fuel Pump/CCRM
P
Not Used
R
PCM
15
PCM Memory
S
PCM
30
AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV
T
Alt./Reg.
15
Generator
U
Air Bag
10
Air Bag (Dedicated)
V
Trans. Light
10
Transmission Indicator Light
W
Fan
10
PCM Fan Monitor
X
Diode
Hood Lamp Diode
Y
Relay
RH Trailer Turn/Stop/Hazard Lamps
Z
Relay
Powertrain Control Module
AA
Relay
Windshield Wiper Speed
BB
Relay
LH Trailer Turn/Stop/Hazard Lamps
CC
Relay
Windshield Washer Pump Motor
DD
Relay
Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps
Color Code
Pink
5
Tan
7.5
Brown
10
Red
15
Light Blue
20
Yellow
25
Natural
30
Light Green
40
Orange
50
Red
60
Blue
the smell of coolant could be the air drawn in form the engine compartment
through the air intake that is at the base of the windshield on the passenger side.
first rate my friends. thankyou very much.
