My HP pavilion dv2713TU laptop does not start, blank screen.
my laptop HP pavilion dv2713TU was working fine , but yesterday when i press the power button all the indication lights came up in the power button and keyboard but there was no display, no POST message, no bootup, no beep messages, totally blank screen like dead. after few seconds the indicators went off in power button and key board . i replaced RAM, Battery, Hard disk, CD drive, but still no response. please somebody help me with this problem!
I think the problem with your laptop is that the operating system on your laptop is corupt, that is why the windows is not responding. I will advice you reinstall the operating system on your laptop, if the operating system can be reinstall, the windows should work fine and respond.
1) Connect an external monitor to the monitor port of your laptop. 2) Shut down your system from the START menu. 3) Take out the battery
4) Leave power cord in for 2 minutes...then REMOVE it.
5) Press your on/off button for 45 seconds.
6) Make sure your screen is at greater than 90 degrees 7) Plug in
8) Press your on/off button to power laptop.
I suggest you to reinstall the operating system once, there might be some problem with the operating system so your screen is going blank before the operating system loads.
You can reinstall the operating system by using the re-installation disc.
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( </ ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your HP driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Well, believe it or not. It's good news that it still works with the external monitor. That means it is not the video card which is embedded in the motherboard and is very expensive to fix. Here is a link to disassemble instructions for your motherboard. Scroll down till you see the dv9000's that should be your laptop. Good luck
click here http://www.hp.com when at page select support and drivers make sure drivers and firmware check(at left)
type ur model details in field...next ..verify model from list ...next....select os ..here are all the drivers needed.
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
