The dim display could be caused by a faulty inverter. The inverter supplies high voltage to the CCFL lamp that provides the back light to the LCD screen.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
SOURCE: Sony Vaio Display problem
Since the Sony Vaio VGN-CR220E works except that the display is dark, then it
would be safe to assume that it is only the LCD display part that is
the issue. Often LCD display (of laptops) are working but only that you
can not see the actual display. One way to verify is to shine a flashlight
at an
oblique angle to the screen, semblance or part of the desktop could be
seen s what you have done. If the
desktop could be seen (albeit very very dark background) then it could
either be the CCF Lamps (cold cathode florescent) or the inverter that
powers the lamps.
Often, the defective component would be the inverter. It is
relatively easy to replace the inverted. It is sometimes more difficult
and challenging cracking open the casing of the display panel of the laptop than replacing
the inverter. Additionally, inverters are readily available online. It
is also not surprising that inverters for other brands/models would
also be used in your Sony Vaio VGN-CR220E .
Of course another possibility is that there is just a loose connection or a cold solder in the LCD panel display's circuit boards.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope
this be of initial help/idea. Pls post back
how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Sony Vaio Laptop Display Screen problem
even if ur in warranty period they wont change ur display so try to take any serivece center and change other wise in any laptop try to get
any help so first just see sony engineer get his assiant usually they use have contact where u can get serviced
SOURCE: my sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
SOURCE: how do you replace a sony vaio ux lcd screen?
Basically remove all screws holding the front bezel (screws are behind the rubber thingies). Once you have pried off the bezel there are several screws on each side of the screen. Removing these will be needed, along with any remaining screws on the top and bottom. Once the screen can be leaned forward, with a sheet of paper towel, on the keyboard. There is a long connector at the top of the screen; remove this connector. Another smaller connector is at the bottom, remove it as well. This ought to get you well on your way!
