20 Most Recent
Sony VAIO VGNNW240F Notebook Questions & Answers
Sony VAIO VGNNW240F randomly powers off
The Operating system maybe corrupted but your files are still good. Try to run a system restore and before the date you notice the system fails to start.
12/8/2017 8:23:52 AM •
Sony VAIO...
Answered
on Dec 08, 2017
Sony VAIO VGN-NW240F/B sometimes will
reformat HDD reload OS; i.e. windows then restart
your computer is saying that the hard drive can no longer find the operating system as it is corrupted
11/6/2017 1:08:57 AM •
Sony VAIO...
Answered
on Nov 06, 2017
Webcam stopped working
do a search for driver utilities. it'll give you a break down of updates/drivers and patches you're missing. it may help. but this could also be caused by an anti virus
7/31/2013 12:37:24 AM •
Sony VAIO...
Answered
on Jul 31, 2013
How to access recovery partition of Sony Vaio
Hi j5rak,
You can use the VAIO Care Software to access the Recovery Partition within the Operating System.
To open the VAIO Care Software, click Start, All Programs, VAIO Care folder and then click VAIO Care. Then, in the VAIO Care window, in the left pane, click Recovery & Restore . Then you can select the required option in the Recovery & Restore window.
You can also access the Recovery Partition by pressing and holding the F10 Key while restarting the Computer. At the Edit Boot options screen, please press the Enter Key to launch the VAIO Recovery Center.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
8/17/2012 7:13:20 PM •
Sony VAIO...
Answered
on Aug 17, 2012
How do i run windows 7 and ubuntu side by side in
Download ubuntu iso from www.ubuntu.com and burn to a cd or usb. You can choose either a 32-bit or 64-bit iso from the website and before choosing, check if your windows is 32 or 64-bit in "System" under "Control panel".When you boot from the cd/ usb you will get to the install interface where you can choose to install ubuntu along windows. Then you can choose how big you want your ubuntu partition to be and that's it - the installer does the rest of the work. You can now choose between windows or ubuntu at every start up.
11/16/2011 10:09:41 PM •
Sony VAIO...
Answered
on Nov 16, 2011
My camera not work how to fix the problem
Options:
- install the correct driver and software of your cam. consider the OS compatibility
- If intalled driver and software not worked then the cam is already damaged.
3/28/2011 1:10:25 AM •
Sony VAIO...
Answered
on Mar 28, 2011
I need a recovery disc
Follow the link below to the Sony website. On the right hand side of page it say's "Purchase the original CD's." You can buy the recovery disks for $28.95 from Sony.
Click Here
1/26/2011 7:33:52 AM •
Sony VAIO...
Answered
on Jan 26, 2011
When i restart my notebook...i
A)please do these steps correctly:
1-open back lid and evolve battery.
2-wait 14 minutes.
3- turn on notebook.
B)if it doesn't work:
use an external monitor. in fact connect video port to an external monitor.
C)your notebook is likely to be damaged so take it to a guarantee center.
1/8/2011 3:19:28 PM •
Sony VAIO...
Answered
on Jan 08, 2011
Need to copy of recovery discs with operating
Recovery disk can be save as system back up files and then reinstalling it again. Try to ask your friend to give you system back up files(same operating system) which can be save using external Hard drive or USB flash disk and install this back up to your computer to work again or if your computer is not working try to boot your computer in CDROM and use the back file to restore your system.
12/28/2010 6:40:14 PM •
Sony VAIO...
Answered
on Dec 28, 2010
Enter BIOS setting for the
Hi jeeplover4vr,
Please press and hold the F2 Key while restarting the Computer to access the BIOS Utility Windows/BIOS settings. Please make sure that you press and hold the F2 Key at the Sony VAIO Logo screen while restarting the Computer to access the BIOS window. You may need to press the F10 Key to Save the changes made, F9 to restore the default values or Esc to exit the BIOS.
Hope this helps.
Please post back if you require further assistance.
10/21/2010 1:43:11 PM •
Sony VAIO...
Answered
on Oct 21, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
