There is no model number LBP-810, it's missing numbers or wrong.
There is a LASER CLASS 810.
You need the correct model number to find them.
here is the page if you get the right number.
http://www.usa.canon.com/cusa/support
You can try install driver from HP LaserJet 1100 or HP Universal Print Driver PCL5 64Bit
Dude, this LBP-810 laser printer does not supports Windows 7 64 bit. It only supports Win7 32 bit instead.
Please check this link for 32 bit version:
http://support-asia.canon-asia.com/contents/ASIA/EN/0100242701.html
There is no 64 bit driver for this model (Canon LBP-810)
One solution is to use a 32-bit driver in compatibility mode.
32-bit Canon drivers can be found here
LBP 810 Canon Europe
Instructions on the of compatibility mode in this context can be found from this link
need help for windows 7 x64 bit driver for Canon LBP 810 Canon or windows...
12.March.2015
SOURCE: canon LBP-810 driver for vista 64bit.
Hi
Drivers of your printer model for windows vista 64-bit are not released yet.
check this link -
http://www.canon-europe.com/vista/en/compatibility_table/laser.asp
Thanks
SOURCE: Canon lbp-810
Hello there DaBest-G ...
You're right of course, there is no driver for this particular device provided by Canon http://software.canon-europe.com/products/0000551.asp. They only support Windows 98 thru 2000.
However, it APPEARS you may have the good fortune there was enough demand in the wild for someone to have developed or tweaked one. Give it a try: http://driverzone.com/device.php?id=71685.
Good luck ... GOD-speed .... and please post back if you have any further questions, and/or just to let me (and others in similar need) know how things worked out.
"Today's the best day of my life...and NOW you're part of it!"
SOURCE: Have downloaded driver for my canon lbp-810
Double-click the downloaded file, to run the downloaded "installer" for the device-drivers for your printer.
SOURCE: Windows 7 64-bit driver for Canon LBP-2410
Canon replied to me saying;
That printer is not compatible with a 64bit system.
Those drivers on the internet are just for 32bit, unless specified
differently
