MULTI-REGION CODE REQUIRED
SOURCE: Remote code for DAV-IS10
Hey guys I was looking around as well ...I found a universal remote that actually worked A++++ .....the name is SONY multi brand remote commander RM-V210 the trick is try under the BOSE code it worked for me picked it up at Walmart for like $12 bucks..
SOURCE: how to play multi region disc in sony hometheatre dav-dz280
your player comes as a multi reader player..
SOURCE: Hello I have a Sony
what you will want to do is go into your user manual and look up factory defaults reset this should return your tv to its firmware and let you adjust or change your region
hope this helps
Robb
SOURCE: Code for making Sony DAV DZ270 region free
HOLA QUE TAL COMO ESTAN ... TENGO UN PROBLEMA CON MI DVD MODELO DAV DZ270 ENCIENDE PERO ME DICE PROTECTOR Y LUEGO PUSH POWER ...Y NO SE QUE HACER .....ME IMAGINO QUE ES PROTECTOR Y NO SE COMO QUITARLO ... ALGUIEN ME PODRA AYUDAR... LE AGRADECERIA MUCHO... GRACIAS
SOURCE: Need an unlock code for Sony dav dz 280
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__dre458
