Mildew in woods refrigerator
If it is being used, it should be too cold for mold (Mildew) to be able to grow. Upright refrigerators already have a circulation fan in them. Mildew won't form in an environment that cold unless the fan is not running and there is a small air leak around the door seals. The picture above looks like a commercial box. If so, the fan is normally mounted and easy to see, mounted on the top panel, inside of the box. If its a residential model, the fan can be berried behind the back inside panel and difficult to access. If there is a switch visible around the door frame, pushing it in should start the fan. I'm guessing that the mildew is present on the door seal? Try sliding a stiff dollar bill between the door seal and the refrigerator all the way around the door. If it makes it in any where, the seal is leaking at that point. If I am way off with all of this advise, let me know in detail how this is wrong and I can go from there. Hope this is good advise for you. Let me know. Good luck.
