Bougt secondhand can,t change forign language back to english
Press the MENU/OK button to display the menu. Press cursor-left, use cursor-up/down to select the wrench icon, press cursor-right, select the third item on the menu (talking head icon), press cursor-right. use cursor-up/down to select the desired language, and press MENU/OK. Press the DISP/BACK button to exit the menus.
If you need a manual you may download a copy here.
SOURCE: Wrong Language
2 possible solutions for you. Take the batteries out. Press the power button (with batteries out). Nothing will happen. It's OK. Leave batteries out for 4-6 hours. Re-install batteries. Camera should default to initial set-up screen, where it will ask you for the language of choice.
Solution 2 is turn camera on. Press menu and navigate to set-up (configuracion). Navigate to language (lang.) and select english. That should take care of it. Hope it helps.
SOURCE: language change
sony did not add language option in this camera DCW-T10, if you buy it from Japan. But SONY must provide the solution to this problem. I am facing the same problem....
SOURCE: i cannot change language of my camera to english
hi i have a lumix camera and the language setting is Urdu how can i change it to english
SOURCE: the language of my fujifilm camera changed automatically
Press MENU/OK to bring up the menu. Press up/down to highlight SET and press right to bring up the setup menu. Select "LANG." from this menu, press right, and make your selection.
