20 Most Recent
FUJIFILM A170 Digital Camera Questions & Answers
Need driver for computer
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Cannot import pictures to computer
Protected card message on screen
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I can't open my camera
If you left batteries in the camera...chances are they have leaked and now are corroded. The only thing that I can suggest is you take a very small flat tip screwdriver and try to pop it open. Be very careful not to set the camera on your lap while doing this, you'll want to set it on a hard smooth surface, and in case the batteries are leaking put the camera on a plastic bag.
How do I get the protected card option turned off?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Card
The car can only go in one direction and flipped right side up. If trying it turned around doesn't help, make sure it is the right card for the camera.
Copy photo from FUJIFILM A170 SD card
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.If you're asking how to copy the pictures from the card to somewhere else, please reply to this post and specify to where you'd like to copy the pictures.
Pictures wont load
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
I have a fujifilm 10megapixel
I tried your '3 times a second' and that works on mine too. Went to Future Shop (where I bought it) and basically said its a write off.
My camera turns on but it cannot take picture, I don't know why? the last time I took a picture the screen just went black and now it just been like that .
A CCD problem would explain the
lines on your pictures and the lines on the LCD (since the CCD is used
to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used
in digital cameras.When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.Some
symptoms of a defective CCD
include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card. In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
I have downloaded the cd that came with my camera,
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
