My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
